The sort of shots I would like to achieve are split screen shots so you can see above water and below water at the same time. To do this the dynamic range of the camera needs to be very high, which is part of the reason for the high end, and large, camera. Underwater will be much darker than above the water so to be able to get a proper exposure on both you need that sort of camera. The work I would be doing with the craft would be for TV, again hence he need of high quality.
However only a small amount of the camera, less than half, would need to be submerged for the split screen shots. So that should help me out.
What sort of motors do you use when you don't need speed but need to move a larger boat?
