RCU Forums - View Single Post - Electric 1/5 Miss Bud
Old 01-08-2021, 07:25 PM
  #33
RAMMJETT
RAMMJETT's Avatar
If you want more authority make the elevators longer . this will help more then making the stab wider because it will take less deflection for the elevators to do the same job . if you make the stabilizer bigger it will take bigger elevators to overcome the stabilizer . so in effect you will have the same effectiveness but more stability because of the bigger stabilizer . .. you can dial down big control surfaces if need be but if you use large deflections on a small control surface the foil will stall and become ineffective, I could see that being a problem with a Kadet with floats because of the very short elevators . .. cheers ..
