Originally Posted by
flyloose
Ya it’s insane how a jet like this can chew through the output slots. I bought a PB Royal and great piece of kit. But the UDI 16 protocol with Jeti limited us to 16 channels. It’s was a real pain trying to work around that. So I decided to just bite the bullet and get the CB 400. 24 channels and 24 slots. And can you believe we still needed an external sequencer to give even more slots.....lol 😂
I believe you could add receiver in Exbus for even more servo, I'm guessing if a guy uses air retracts then you would need a separate servo for each brake and on for steering.
I'm using a GS200 electron control so it does a lot of the extra works the transmitter plus ABS brake setup for keeping the plane straight and turning with the help of brake to pivot the plane.
Like the air brake between the verticals, it will help to stabilize and slow down the landing speed.
