Skyliner 30cc mxs-r in red
Hi, For sale is a Skyliner 30cc mxs-r solid red in color. Looks to be the same model as yours but completely different covering color and design.
Im wondering if it is in fact mechanically the same as yours. The listing at Generalhobby.com is as follows: is this the same as your plane?
Tony
Specifications:
WING SPAN: 75" (1915mm)
LENGTH: 69" (1760mm)
WING AREA: 888sq in (57.3sq dm)
FLYING WEIGHT: 9.2-11lbs (4200-5000g)
ENGINE:26-35cc gas, 2000 Watt Electric, 1.10-1.40(4C), .91-1.1(2C)
RADIO: 4CH / 5-6 servos
Features:
01. Latest structure
02. Super quality
03. Easy installation
04. Complete with accessories
05. Low wing loading makes it easy to fly
06. Light weight construction with high structural strength
07. Excellent aerobatics and 3D performance
08. High performance hardware includes:
Fiberglass horns
2.5mm Ball linkage control system
Advanced rubber wheels
09. Two pieces removable wings and stabs
10. Aerofoil tail wings
11. Carbon fiber wing tube
12. Carbon fiber tail wheel assembly
13. Anodized aluminum long servo arms included
14. Servo extension safety connector clips also included
15. Carbon fiber rods to make the wings light weight and strong
16. Scale canopy
17. Fixed ring inside cowling for easy build
18. Pre-hinged control surfaces ready to fly
19. Pre-mounted and plumbed gasoline tank ready to fly
20. Pre-installed servo wire tube
21. Carbon landing gear
22. Carbon reinforced fuselage
23. Powered by Electric Glow or Gasoline
