How to program Taranis with homemade "tank"
Hi, i've search around, and i cant seem to find how to do something that i tought would be simple.
I've made a tank, simple, 2 track, with each a drone motor with a ESC each, both plug strait to the receiver.
Both stick on the Taranis X7 are set to self center, and i want each track to be control by one stick.
So i need to set the "0"/neutral to the center of the stick and 100% at the top. (Or you can see it as both stick are throttle, but need to be neutral at the center) .
I'm able to get it to work with a Elevon mix, but thats not ideal.
Seem i will need special ESC to get reverse, so that gonna be for later, but if you know how to set that up at the same time, the knowledge is welcome.
Thx for any help.
P.S. The tank i'm refering to, i'm not the creator : thingiverse thing:4234076
