RCU Forums - View Single Post - Electric 1/5 Miss Bud
Old 02-15-2021, 03:55 PM
  #36
RAMMJETT
RAMMJETT's Avatar
Just finished the exhaust header pipe, the ports are so massive on this engine I needed to use SS pipe for a ZDZ 210cc engine , was a little tricky having the header pipe exit the engine and not cover the mounting bolts .. The pipe is a Greeves that has been cut in half and shortened . added a extra baffle plate to help cancel noise . will have to do some testing to make sure the exhaust is not to restrictive .. also mounted the fuel tank . once the drive shaft arrives I can finish her off and get it read for paint ..
