Originally Posted by
Cfe7
Hello Bill M,
Is the R7014SB receiver compatible with the TM-14 TX module?
I'm having problems linking the two together.
Yes it is.
First-set the RX mode to FASST
Then use the Multi FASST protocol setting in the System type menu of the TX.
Linking is done by turning the TX on and holding the TX antenna close to the RX antennas. Then hold the LINK button down on the RX while turning it on. It will blink red, then go solid green.
There are two LEDs near the antenna end of the RX. One in the MODE LED the other is LINK. Both will be green when the RX MODE is FASSTest and a signal is being received. Only the LINK LED will be green if the RX mode is FASST.
