Originally Posted by
DaleCS
Chad - I could get you sketches, dims off the TF Hellcat tank. I don't know how many TF Hellcat owners are out there that may want to buy a replacement that could plug & play with the TF mount/release mech. I was thinking about documenting the design to some extent, should I ever need to rebuild/replace it. The internal framework will be 'close-enough' - should've traced the pieces before assembling, installing in the tank, but wasn't thinking about TF failing.
Go ahead and send it Dale. Once I've got the machine and get it set up the drop tank might be a good learning project. There will most likely not be any need for the internal structure on a printed tank but if some is needed it can be printed integral to the tank.
