RCU Forums - View Single Post - Bavarian Demon Cortex PRO is here!!
Old 02-27-2021, 08:10 AM
  #939
rfbenn
Originally Posted by Tip22v
if the wire loom fixes the problem then the problem is not likely noise from the turbine. Are both of you using Futaba sBus connection? I’m running 5 cortex pros in 5 different jets with Jeti EX bus and have never experienced any of these symptoms. This is very concerning though...
The problem showed up on the initial set up in the workshop using Sbus, as soon as I set it up with the loom ( which doesn’t use sbus) all the surface trims were fine.
I have tried to contact Bavarian but they have not replied as yet.
Rob
