Originally Posted by
rfbenn
The problem showed up on the initial set up in the workshop using Sbus, as soon as I set it up with the loom ( which doesn’t use sbus) all the surface trims were fine.
I have tried to contact Bavarian but they have not replied as yet.
Rob
This is an issue which has come up a few times. The Cortex Pro does not shift the centering. If this is happening it must be something in the SBus output from the RX that is shifted. Please make sure you are using SBus, not SBus 2.
