Originally Posted by
Dansy
Pretty simple, box it with the form on Kingtech USA....write about the pump.
Dirk will strip it, clean it like new...change the bearing, zero the time and run it to check everything out.
$300.00 usd for the 25hrs.......but if it was run with a 2 stroke oil, which cook on the parts, you will be charge extra for the cleanup..
Ok Thankyou for the help, I only use kingtech oil.
