RCU Forums - View Single Post - Ziroli A-D1 Skyraider
Thread
03-18-2021, 05:40 AM
18
gonzalobures
Repairs and beefing up what I consider a design which can be improved.
Both sides repaired. Also triangular stock was epoxied to main wing spar/rib joint pinned with hardwood dowels.
Left wing
Doubled 1/8" original retract mounting rib with 5/16" plywood and balsa rib with 1/8" plywood. This was done on both ribs on the other side of this same retract as well as on the right wing. Hard wood spars were also installed tying uo the 4 ribs since the lead edge is not a strong point due to retract penetration.
To improve lead edge strenthgt, a 1/4" plywood brace was epoxied tying the lead edge to both ribs.
Done on both sides of the ribs and both wings.
Reply
Like
gonzalobures
View Public Profile
Send a private message to gonzalobures
Find More Posts by gonzalobures
View iTrader Profile
