Originally Posted by
Justaddwata
Going to depend (to some extent) on what you are starting with.
Realistically you should lay out the boat - figure the best location for the motor/s keeping the balance of the boat in mind (for most boats it is ideally the finished build should weight balance between 25 and 35% from the transom of the boat). Also determine where you will be mounting radio box (and the servo layout needed), fuel tank, exhaust, Air scoops and air flow, floatation (in the hull and under the hatch), transom hardware. Personally I have not got a particular order I use when doing a build. Some things make more sense than others. Realistically the transom hardware and the motor should be installed before other components as they don't have much flexibility on where they should be.
Post some pics of what you are building!
I'm In Australia and waiting for parts to arrive from the states that will prob take forever with everything going on, but as soon as I start I'll for sure post some cause undoubtedly ill be asking more questions...
