Well the manual is fuzzy on this. The back cover on this engine is not specific to just this GAS engine. I think it not wise to attach the pump to the back cover because gasoline increases the temperature of the engine which could be detrimental to the plastic/polymer pump. Hence the reason they talk about remoting the pump away from the engine. What got me confused was the video of Brian Winch testing this engine with the pump attached to the back cover of the engine......but then again that set-up was on a test stand and not buried in a cowl.
