Epoxy inside the tank
I blew out any dust and wiped down the inside with acetone
After painting epoxy inside the tank I took care to clean out the holes. I used West Systems 105 and 206.
Tubes will be glued in with hysol before the tank is closed up
The inside track of the mount was coated. If there is a fuel leak here I don't want the wood to be a sponge
After coating the inside I flipped the rear section over and coated the rear face. After the tank is closed I will only have to coat the top and sides.
