12FG Question
I am setting up an airplane with forward retracting nose gear. I need to disable the steering when the gear is retracted because the steering cables are still tight.
I have steering on Aux 3 mixed to rudder. In the program mix setup screen, I assigned the retract switch to turn the mix off when the retract switch is in the up position.
The servo still moves with the stick. What am I missing?
