Originally Posted by
Fishgod123
Can anyone give me an idea of what kind of flight time you can expect with a small battery for a sloap soarer? I'd be looking at 3 small servos and a receiver. Just trying to see how big of a battery I'd need. I'm thinking like 150-600mah 2s and hoping for something around an hour
In slope soaring in medium to higher winds where you'll likely be doing aerobatics where the servos are moving more often than they are still you'll use up power a lot faster you'll want higher capacity cells. If you're looking at around 2 hrs of air time per day I'd go with something up around 850 to 1000mah to be sure you don't run low. And even a little more would not be out of the question if the servos are digital which tend to use more power for the same movement.
