RCU Forums - View Single Post - Hawker Hurrican Mark IIc 1/5 woodkit
Old 04-07-2021, 10:44 AM
royal_chris
Before glueing the hinges, I usually enlarge the center hole and put some brass guiding in there. Along with the 2mm steel wire, the axis has zero play then.
Afterwards I use thick epoxy to glue them while the axis is always inserted to avoid twist and surprisings after everything has hardened.
