I wish you luck on your maiden! The CG on mine was forward the book CG a little bit. I started with the recommended CG and it was too tail heavy.
Here is one thing to keep in mind. These planes are so small, that slight variations with glue etc can significantly impact CG. Mine and JohnVHRC's were more tail heavy, while others were more nose heavy out of the box.
I hope that helps!
GB
