RCU Forums - View Single Post - Hawker Hurrican Mark IIc 1/5 woodkit
Old 05-02-2021, 03:08 AM
  #33
royal_chris
Just a few minutes of parts preparing the parts and a bit of white glue, the rudder stab is set up.
Self adjusting, you don't even need a plan underneath. Woodbuilding can be fast, if the designer did his homework.
The 6 mm Balsa trailing edge is also the last fuselage former, this helps to build a solid leightweight rudder.
