Originally Posted by
Dave Wilshere
I just set the travel with an offset for each surface, left or right input. Then all expo and D/R changes follow the same percentages.
it’s rare to have a model where the travel percentages are the same anyway. They might start at the magic 100-100% but to get perfect rolls having 98-99% one direction is common. So for top hinge surfaces where you need more down aileron than up I have 100% up direction and 105% down. (Or 95% up and 100% down direction etc)
I'm assuming you're referring to just changing the endpoints in the sevo menu? That definitely sounds like the simplest option. I'll go with this method and try out the differential wizard once that comes out.
