RCU Forums - View Single Post - Brushless car vs. boat motors - make me smart!
Old 05-09-2021, 05:03 AM
mugeyman
mugeyman's Avatar
hi @ 9000 and BKoz559 well glad we helped stay with the 36mm dia can motor stay with the motors around 2500 to 2850 kv which is probably around 13t turn motor you will need to gear it properly
due to weight of buggy , run time , track , add a fan to cooling motor , temps should be no higher than 170 . i never heard about a LC BUGGY KIT , mostly the race buggys , truggys TEAM ASSOCIATED , LOSI , XRAY, TEKNO , SHAUMACHER , KYOSHO these are some of the best on the planet for racing and bashing, see the youtube videos on this stuff for set ups motors gearing racing for 2wd and 4wd your
buggy has a internal gear ratio divide pinion into spur x internal drive ratio = FDR FINAL DRIVE RATIO , then toy can go up or down in pinion gears as to keep motors and esc with in a good temperature ok hope i helped ok mugey
