RCU Forums - View Single Post - dual elevator servo setup questions
Old 05-10-2021, 08:28 AM
jigeye
Default dual elevator servo setup questions
Newbie here with syncing elevator servo question(s).
Extreme Flight Extra 300-85in.
Spektrum ix12 transmitter
SpektrumAR20310T receiver
Elevator servoes (2)
On different channels (aka not mixed together).
Servo geometry correct and set up with no subtrim on either elevator servo.
Trying to set up low rates using angle meter (android).
Dual rate setup was successful on L elevator (up20 degrees/dn20 degrees)
When checking R elevator up was 20 degrees (good) but dn was only 16 degrees (bad). In other words I cannot figure out how to get the R elevator to go down to 20 degrees (vice 16 degrees right now).
I am unsure when I go into “dual rates” on the transmitter, which servo it looks at (aka L elevator or right elevator or both).
I know there is a way to fix the r elevator down issue, just don’t know how.
