Now I'm getting somewhere:
Specs
More coming
Specifications (original Stipa-Caproni)[edit]
Data from NACA Technical Memorandum nē 753 : Stipa Monoplane with Venturi Fuselage,
[5] Aeroplani Caproni: Gianni Caproni and His Aircraft, 1910-1983
[6]
General characteristics
- Crew: 1 or 2
- Length: 5.88 m (19 ft 3 in)
- Wingspan: 14.28 m (46 ft 10 in)
- Wing area: 19 m2 (200 sq ft)
- Empty weight: 570 kg (1,257 lb)
- Gross weight: 850 kg (1,874 lb)
- Powerplant: 1 × de Havilland Gipsy III 4-cylinder inverted air-cooled in-line piston engine, 90 kW (120 hp)
- Propellers: 2-bladed ground-adjstable propeller
Performance
- Maximum speed: 133 km/h (83 mph, 72 kn)
- Landing speed: 68 km/h (42 mph)
- Service ceiling: 3,700 m (12,100 ft)
- Time to altitude: 3,000 m (9,843 ft) in 40 minutes
- Wing loading: 44.73 kg/m2 (9.16 lb/sq ft) at 850 kg (1,874 lb)
- Power/mass: 0.105 kW/kg (0.064 hp/lb)
- Take-off run: 180 m (591 ft)
- Landing run: 180 m (591 ft)
