Originally Posted by
YellowBlueBird
Question for Scale Only For Me.
It looks like WR-LPU is going away in favor of Pennant Top Coat. They say to use a paint pot instead of HVLP gun. Have you had any experience with the new paint and what gun, tip size and pressure do you use with the WR-LPU? It is my guess that the same thing will work with the new formula.
Jerry
Well, No,, that's the first time I've seen that,,, that announcement must have been posted after I placed my last order
As far as application,, can't see why it can't be applied with a HVLP system or Airbrush like I have always done,
That is likely just the recommended method for marine applications on the label,, having worked on boats in my early days out of High School, they'd be putting on a heavier wet coat vs how I use multiple mist coats on my models..
Seems as the have the same crosslinker recommendation,, no doubt it will have the same chemical resistance and still be fuel proof,, but no way of knowing 100% without real world testing
good luck
