If the pump will work with the preset throws on the DG channels it will work. However, some devices need different limits and the DG channels cannot be adjusted. You can connect power to any on the ports, they are all wired in common. Can you connect smoke to another channel where you can adjust the endpoints? Which readio are you using?
Also, where do you fly? I am in Ladera Ranch and fly at OCMA.
