Not to nitpick but if it's not too late, your masking on the fin has too much curve and doesn't come down low enough on the leading edge of the fin. On the full scale the bottom edge of the blue stripe almost flows right into the curve of the lower part of the fin. The line that curves up towards the leading edge (molded line) also shows on the full scale that the front point of the red and blue stripes end below the point on the leading edge where that molded curve meets the edge.
Its a lot of work to mask, I hate masking, and what you've done looks great but the fin and the left side of the masking on nose of the fuselage (right side looking head on) are the two things that really jump out. There is a funny wobble on the nose on the left side of the fuse (cockpit view left)
