RCU Forums - View Single Post - 200XBL Starter Voltage
Old 07-13-2021, 03:21 AM
LA jetguy
LA jetguy's Avatar
Joe .. try dismantle the starter motor and with a towel clean the O ring inside the clutch of the starter motor…. Then with a little alcohol clean the “nut” on the turbine wheel where the clutch engages….
Based on the age of the turbine either you have to lremove the three screws on the tripod holding the starter motor or unscrew the starter motor housing to get to clean the it out
David
