Never done a 4 blade the principle is the same. Once on a balance device the heavy blade goes to the bottom and you can start by adding weight opposite or sanding there. Just dont make the mistake like I've seen many do on a two blade. Many balance so it sits horizontal on the stand. This is wrong. If balanced it should stop anywhere.
David
