Ralph we had to do the following to make all the functions work correctly I had to reverse the TX Gear function and then flip the retract connection plugs on the gear controller so the gear would travel in the correct direction, You have to flip the switch up and then down or visa versa at first to get the gear back in sequence. I had to do this on JP gear in the Joker and helped my friend with gear in his Avanti XS, he still is trying to get the steering compensation going the correct direction.
BTW do NOT leave your battery plugged into this device between uses as it will discharge your battery!
Ralph does the brake battery need to be plugged in during calibration???
