RCU Forums - View Single Post - Strange Tank Shut Off Problem
Old 07-22-2021, 07:29 AM
Crius
Did it come with the V1 mfu? The way to tell is to look for the six small sockets where you would attach the servo cables if you want to use your own transmitter. If your mfu is not capable of using a hobby grade transmitter then it's a V1. If you're in the United States, I can send you a V-1 mfu that I know is good and you can try it and see if that eliminates your problem. All you have to pay is postage, probably $8.50 for the small flat rate box. That is, provided you have a United States ZIP code. If you're outside the country I'm not sure I can help you.
