Do you have enough post yet to post photos? That would really help. If you got the stock on off switch there should be two black wires attached to one of the outside pins, one red wire attached to the middle pin, and one red wire attached to the other outside pin. You twist the two red wires together. Make sure your battery is unplugged when you do this. You know what, I can make you a video. Standby.
