RCU Forums - View Single Post - Strange Tank Shut Off Problem
Old 07-23-2021, 12:02 PM
Crius
A fuse is always a good idea, but just to be clear, you will solder one red wire to the center pin on the switch and one red wire to an outer pin on the switch. The two black wires both get soldered to the other outer pin on the switch. Just like in the video. And personally, I usually put my fuse inline on the red wire coming from the battery.
