RCU Forums - View Single Post - JetCat smoke pump user manual
Old 07-24-2021, 01:46 PM
Dave Wilshere
If you are activating the pump from the ECU-no it will only work with JetCat. Using a radio channel to activate and control flow you can use JetCat or PB pumps with any turbine, because it’s not controlled by the ECU.
