Originally Posted by
Dave Wilshere
If you are activating the pump from the ECU-no it will only work with JetCat. Using a radio channel to activate and control flow you can use JetCat or PB pumps with any turbine, because it’s not controlled by the ECU.
Thanks Dave, that's what I was thinking but wasn't sure.
