RCU Forums - View Single Post - Bavarian Demon Cortex PRO is here!!
Old 07-24-2021, 06:19 PM
  #954
orthobird
Having some difficulty setting up mu Cortex Pro
I am using CB 400
Jeti DC 24
i went to function assignment and set up P7 (knob on right side) as Gyro Sens.
then, i went to dual rate Gyro Sens, and set up a switch SG to kill the gyro, so it is at 100%, and when I flip to Zero and position 3, the dual rate is set to 0%, 0%
in device explorer, i see:
Rx1>>>>
Switch>>>>
I then turn system on, insert plug, the cortex pro recognizes the 2 receivers.
then, i turn off the system''
then, I will turn on system with bind plug in, and go thru the training
I've got it memorized since I ve done it, probably 50 times!! LOL
bump right aileron
bump left aileron
bump push elevator
bump pull elevator
bump right rudder
bump left rudder
2 bump, i release the left rudder to center then turn the knob (P7)
and I never get the green lights***********************
anyone seen this before?
