Originally Posted by
elkriverscott
The numbers came off of the makers spec sheet. Trying to come up with something to solder to increase receive range. As I recall the tiny antenna length on the drone is just as long as it should be however I am curious if one can attach a four leaf antenna or a flat "wheel antenna" to improve range> Thanks
Good luck on that. Standard receivers should not have a range problem for line of sight flying. You are flying LOS, right?
