RCU Forums - View Single Post - JetCat smoke pump user manual
Old 07-25-2021, 01:34 PM
Thud_Driver
Thud_Driver's Avatar
Assuming I got the right part of the right manual, here's a translation. Looks like the pump has to have the Rx mode activated.
In Rx mode, the pump is controlled via a free receiver channel. A switch /
Slide or rotary potentiometer on the transmitter side can be used for the pump control. If e.g.
If a 3-position switch is used, two different delivery rates can be set and
then select
Position 1 = off, position 2 = small delivery rate, position 3 = large delivery rate.
When using a slide or rotary potentiometer, the
Delivery rate possible.
ATTENTION: In this mode it is possible to start the pump even when the engine is at a standstill!
Activate Rx mode:
- Free receiver output with the control input (middle connector) on the pump with the
Connect the enclosed cable (plug / plug) (the brown cable must match the green
Show the connection socket of the power supply)
- Connect the power supply (e.g. 7.2V battery) to the pump.
- Press and hold the "+" button on the pump.
- Now switch on the receiver (keep the "+" button pressed) beep.
- Now release the button.
- Set the switch / slide or rotary potentiometer on the transmitter to 'minimum' (= pump OFF).
- Briefly press one of the two buttons beep the "OFF" position is saved.
- Now set the switch / slide or rotary potentiometer on the transmitter to 'maximum'.
- Briefly press one of the two buttons beep maximum position is saved.
- This activates the Rx mode and the transmitter positions for "Pump Off" and "Pump."
at maximum power ”.
- Set the switch / slide or rotary potentiometer on the transmitter to 'minimum' again
Adjust delivery rate / pump output:
After successful activation, the delivery rate / pump rate can now be adjusted:
- Switch on the receiver, do not press any button !!!.
- Set the switch / slide or rotary potentiometer on the transmitter side to the minimum position at which the
Pump is just starting.
- When the pump is running, press both buttons on the pump simultaneously and briefly.
- The delivery rate / pump output can now be increased with the "+" key
- The delivery rate / pump output can now be reduced with the "-" key
- Set the switch / slide or rotary potentiometer on the transmitter side to the maximum position at which the
Pump should run at full power.
- The delivery rate / pump output can be increased with the "+" key
- The delivery rate / pump output can be reduced with the "-" key
