Just a reminder, you don't want to use Alodine in place of a proper cleaning after running in salt water. Alodine is used, in aircraft, to help prevent corrosion. By itself, it's not a "cure all" that can stop corrosion before it starts. It's like putting a coat of wax on a car. It helps protect the car from the various things that will get on the paint but it won't stop everything from getting to the paint. Hope that makes sense
