Hi,
I am setting up a Cortex Pro with Jeti CB220.
When a teach the Cortex Pro the signals, it successfully gives me two blue blinks but the servos do not react. I checked the Cortex Pro with the computer and found the input signal was correctly learned as Jeti ExBus but the output signal is PPM. It should be ExBus out.
I watched the Bavarian Demo setup video (again) and found I'm doing what they show.
I tried all the usual stuff, resetting the Cortex, double checkin the receivers were set for ExBus out.
Is there a special trick for CB220s?
Any tips?
