Originally Posted by
Vinnie6
The threaded hole in the rocker perch has just a slight amount of thread left. I planned on (carefully) epoxying the pin to both sides of the rocker perch. I was going to attack the holes in the perches with a pipe cleaner and mineral spirits. I like the idea of brake cleaner! I DID think about what if I need to remove a valve later. Thank you for the tip about overnight soak in lacquer thinner to dissolve JB Weld.
Vennie^, there is a clear-blue glue that machinists use to glue in cylinders liners on engine blocks (when they replace worn out cylinders) I have seen my friend use it. he gave me some to use on the screws inside of Chevy's rocker covers. he said the screws would never come out...
maybe Garry and or Dave will comment about this glue if it will work for you.
Garry, I sure wish I knew about that 91. LOL
Jim
