If it's to lean or to rich the air bleed screw may not have much effect on idle. I would take a piece of clean fuel tube connect it to the fuel inlet and blow into it to see if the needle passage is open. Then open the high speed needle 1 and 3/4 turn should be enough to run good a little on the rich side.
