RCU Forums - View Single Post - American Eagle 95 in. Hellcat kit Sell/Trade
Old 08-14-2021, 09:31 AM
Check6
My Feedback: (427)
There is no main spar at the center and the outer panels. Usually the wing halves are glued together and then a full slot is cut into the panels. Then a plywood spar both front and back is epoxied in from top to bottom sheeting. This is done after the retracts are fitted so the spar can be glued into the retract boxes. I also have an aluminum tube set up to make it a 3 piece wing or a two piece wing joined in the middle. If you reference the build thread on RCscalebuilder it explains everything. Send me you email and I'll get detailed pics of the wing for you.
Fred
Check6 is offline
