RCU Forums - View Single Post - T34 Bronze Class Setup
Old 08-16-2021, 07:51 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I think you are pushing it with 20%. The engine compression ratio is really at the point where 15% is about the max I would run. That said, try an Enya #4. The Enya plugs are a bit more durable then the OS and with the higher nitro you need a cooler plug. Rule of thumb though for what you are doing is to use the coolest plug you can that will give you some sort of decent idle. Last time I raced we had a rule that required a 4,000 rpm idle.
