Originally Posted by
n8622t
unfortunately it won’t fit…I started out the same way and had to go to the 5-125 and it’s too big as well
OK so just to be clear the diameter they specify on the factory drawing is not correct? The 180 won't physically fit in the cowl?
Did you have to modify the cowl to fit the 125?
I know were slightly off topic but the diameters of the engines being misrepresented is important.
EDIT; I see now the drawing has two diameters and the larger one is basically 11 inches OD
