There is a prop drive hub nut that has to be removed. Look straight down the center of the hub you will see the nut on the shaft. you will need a deep socket to remove it. See parts link, it's item # 2 page # 22.
http://manuals.hobbico.com/dle/dleg0085-manual.pdf Here is some good info on removing the hub nut.
https://www.flyinggiants.com/forums/...d.php?t=220860
