Weird Jeti alarm!
I have a DS 16 in a jet for 4 years with no issues until now. When you turn on the transmitter no alarms. When I turn on the jet I get a repeating alarm "warning capacity" and at top a flashing "alarm C". The batteries test fine and substituting the batteries does not stop the alarm.I have 2 other models with the identical setup (CB200 dual path, 2 R3 Rx, A123 Rx batteries ) on the same transmitter and when I turn those models on no alarms. Having the ECU battery plugged in or not makes no difference. I have never programmed a capacity alarm in the morse code alarms. I was advised to go into the telemetry min max values of the CB200, those numbers appeared OK but I reset the values anyway. The "warning capacity" alarm continues. I have X out all the variables in "sensors and variables" with no effect on alarm.
Very frustrating. Any help would be appreciated.
