RCU Forums - View Single Post - Kyosho EP Caliber M24
Old 09-16-2021, 01:11 PM
GeloCityRC
Default Kyosho EP Caliber M24
Hello all great to be part of this site! I recently purchased a kyosho helicopter at an estate sale and it did not come with the transmitter. Everything seems to be in good order and may not have been previously used. It has an FM RX with channel #38. I have an NOS Futaba SkyPort 6a on channel #42, I swapped the crystal in the RX to match Futabaís #42. Everything lights up as should buy the RX indicator light stays flashing when it should go solid as if it is not reading the signal is Futaba compatible with the Kyosho crystals? The instructions also show it set up in Mode1 which I Personally donít care for. I did test the main motor & tail motor both work fine but no servo movement at all as it does not seems to be communicating with the transmitter. I would greatly appreciate if someone could point me in the right direction to get this running Iím so used to the new Spektrum stuff which is so easy I forgot how the crystals work or if Futaba is compatible with Kyosho. Thank you in advance 😎
