Ahhhhh its a much simpler fix then what I was imagining lol not to mention on the complete other side of the boat then what I was thinking. I'm just not used to the terms yet. But I'm pretty sure I understand now. Basically I'm going to make the back of the boat (Transom) thicker by adding another wall to it essentially, to keep it from flexing like you were describing. This is even easier then what I was thinking since this is an easily accessible area. I could definitely see how the motor could cause this area to break and flex now that you point it out. So this should be the only part I reinforce? when put the hull up to the light, its pretty thin and you can see light right thru it. I know they should be lite weight I just spent a decent amount of money on it and don't want it to blow apart haha. I just want every thing to be as perfect as possible for what I'll be capable of on my first build.
