RCU Forums - View Single Post - Nitro Engine Internal Bearing Supplier UK
Old 09-19-2021, 10:35 AM
Gazza667UK
Gazza667UK's Avatar
Originally Posted by 1QwkSport2.5r View Post
I’m glad you got a suitable replacement. One thing you must be careful of with Novarossi engines; they use odd sizes a x have patented sizes and designs. A lot of engines use a 14x25.4x6 bearing. If your outer race is too small, it can spin in the crankcase and wear out your irreplaceable crankcase. Measure your bearings with precision instruments before ordering aftermarket bearings.
Thanks for your reply. Yes, i did notice the sizes were a little 'different'. I used my digital micrometer to get my measurements.
Ive several 'donor' engines that i measured prior to ordering & noticed the Novarossi bearings were very much the odd size out. Most other bearings i had were actually 24mm OD. But after an hour in the freezer, the replacement bearing dropped straight it.
Every day is a school day in this hobby
